It is currently Tue Jul 22, 2025 6:43 pm
PostPosted: Mon Feb 28, 2005 2:49 pm
I have an indian rosewood back with some tiny streaking of white material. Is this calcium? I know it's natural occurring and that it isn't a fatal flaw, but fairly common. What do you do to deal with it? Thanks, Bruce
PostPosted: Tue Mar 01, 2005 1:43 am
Okay, I've seen this answered before, anyone remember how to dissolve the tiny calcium streaks?
PostPosted: Tue Mar 01, 2005 1:56 am
I may have to go over to MIMF for this one....
Bruce, there was a discussion some time ago on the AG list. I raided a lab and tried a few different chemicals to get the deposits in suspension -- that worked somewhat.   In the end, a spit coast of shellac worked as well as anything.
I suspect what happens is that the oils and color from the wood itself get drawn out by the alcohol and stain the deposits enough so that they're much less obtrusive.
So if they're not too bad, I'd count on shellac.
PostPosted: Tue Mar 01, 2005 2:06 am
Lemon juice on a q-tip or tooth pick bruch
PostPosted: Tue Mar 01, 2005 2:41 am
If it's calcium (which I somehow doubt) then vinegar /lemon juice will take it off.
PostPosted: Tue Mar 01, 2005 3:03 am
Hi Bruce,
I remember seeing a discussion of this problem. I paid extra special close attention because I have some beautiful quartersawn mahogany with white deposits all over. Muriatic acid was recommended, with a cautionary note about what it might do to the color of the wood. I haven't tried it yet but when I do I'll test it on a piece of scrap. Let us know what works and what doesn't!
Best wishes,
Viv
PostPosted: Tue Mar 01, 2005 3:04 am
Your right Colin, you do want to neutralize after you use Lemon juice. The pieces IRW have had with these spots did appear to be calcium or some type of sodium deposits. I see it a lot in Iron wood that I build jewelry boxes from.
PostPosted: Tue Mar 01, 2005 3:59 am
I think it's safer to say that it is some kind of salt exudant. Calcium doesn't play a significant part in plant physiology, sodium does in water transportation. So first off I'd just try wiping down with distilled water.
PostPosted: Tue Mar 01, 2005 5:53 am
Thanks folks, this thread just kept dropping out the bottom before it got a response, I'll see what works.
PostPosted: Tue Mar 01, 2005 3:02 pm
Bruce, I'd try some denatured on a rag and do what Bob says. I should pull the color out of the wood and stain the deposits.
PostPosted: Tue Mar 01, 2005 3:25 pm
Okay, the home remedies worked. I was in the kitchen so vinegar was handy. It removed at least 90 percent of the visible streaks which were all small anyway.
Using a toothbrush and scrubbing them with the vinegar removed most of it immediately. So with pore filling and shellacking, I'm sure that nothing will remain. I knew this wasn't a huge deal, but had never dealt with it. Thanks one and all. Just a little care in the final before finishing will be all that is needed.
PostPosted: Tue Mar 01, 2005 4:19 pm
   This is a natural occuring thing with EIR. I have really don't get worried about it as you need to fill the pores and stain the filler and this takes care of it.
   Sometime alcohol and acetone may get some out but it is still there. It is a mineral deposit and it doesn't allways come out depending on the element involved.
PostPosted: Wed Mar 02, 2005 6:40 am
Colin, the mineral we're dealing with is almost certainly calcium carbonate.
PostPosted: Wed Mar 02, 2005 7:26 am
I'm not sure how the calcium carbonate would come to exude from EIR unless it's a post harvest environmental contamination. I'll check out my stash of EIR and if I have any exudant I'll take it to work and have one of my post grads analyse it.
PostPosted: Wed Mar 02, 2005 8:01 am
I'm neither a botanist nor a chemist, but the calcium is not being incorporated into sugars as part of photosysthesis (therefore, not extruded in any way), it is probably being shunted into interstitial spaces between cells because the moisture drawn in from nearby soil is likely rich in these minerals. Just a guess.
PostPosted: Wed Mar 02, 2005 2:37 pm
Tums?
